TwinTurbo.NET: Nissan 300ZX forum - follow up on resetting IACV and TPS
Subject follow up on resetting IACV and TPS
Posted by slcZ32 on August 24, 2012 at 2:38 AM
  This message has been viewed 285 times.
In Reply To Yes provided you set the voltage to the specified amount >> posted by ZUL8TR on August 23, 2012 at 01:11 PM
Message alright, so i wanna say thanks for everyone's input so what i did today was resetting the AAC by unplugging the yellow connector when the car was warm and then turn the screw all the way clockwise, turn the car on plug connector and tried to adjust idle.... this had no effect on the car.
then i check the TPS voltage, it is where is supposed to be around 0.4 to 0.5 v
so far nothing that i have tried have had any effect on fixing my high idling problems.....Whats next guys?? what other things should i take in consideration???
the only way to lower the idling is by retarding the time thru CAS ... the car drives like crap when i do that
thoughts?
PS i will get a timing light and check timing tomorrow
