TwinTurbo.NET: Nissan 300ZX forum - shouldn't matter if the balance tube is removed (n/m)
aliaZ
on August 23, 2012 at 7:52 PM
WOT vs plate closed is the difference, I think. (n/m)
posted by Haasz32
on August 21, 2012 at 11:22 AM
can bad timing cause low compression?
SaphireZ
11:41:18 08/20/12
It would be the timing belt being off, not the cas position.
Woody75 (Denver)
13:27:39 08/20/12
PROBLEM SOLVED = CAS Sensor
SaphireZ
21:11:18 08/20/12
dude...my car is giving me the exact same numbers!
RonDeezy
22:58:51 08/20/12
Not gonna make a difference. (n/m)
Woody75 (Denver)
10:48:09 08/21/12
Did you recheck the compression numbers?
Woody75 (Denver)
10:47:45 08/21/12
Re: Did you recheck the compression numbers?
SaphireZ
10:56:31 08/21/12
How were you doing it before?
Woody75 (Denver)
11:02:09 08/21/12
Haasz32
11:22:41 08/21/12
shouldn't matter if the balance tube is removed (n/m) -
aliaZ
19:52:40 08/23/12
The standard on a TT engine is 171. I have yet to read
PiotrC70
13:10:23 08/23/12
A compression test is a relative test
BlackholeZ
18:44:19 08/24/12
