TwinTurbo.NET: Nissan 300ZX forum - I'd still find a way to smooth out that surface.
Subject I'd still find a way to smooth out that surface.
Posted by zellamay on August 22, 2012 at 2:12 AM
  This message has been viewed 163 times.
In Reply To the wire wheel actually smoothed it out a lot, but It... posted by inf on August 22, 2012 at 01:14 AM
Message The wire wheel may have taken off the high spots, but it will not produce a flat surface. Keeping it flat is just as important as getting the high spots off. I can't see the whole thing in your picture, but I'd get a flat tool of some sort, maybe a block of wood or metal and wrap some sandpaper around it. You'll be able to see what is going on from the marks it makes. ..... Now, if you've already made that surface a little concave with that wire wheel, there's not a lot you can do about it. Just get as good as you can. It should be okay because you have some unaffected surface that should seal.
