TwinTurbo.NET: Nissan 300ZX forum - The gasket doesn't go all the way to the bearing though
inf
on August 22, 2012 at 1:17 AM
It doesn't even go through, from outside to inside.
posted by zellamay
on August 21, 2012 at 11:49 PM
the width is basically where the gouge starts and finishes.
Scratched gasket surface on transmission front cover
inf
19:11:36 08/21/12
Not really sure on the issue - can you circle or highlight
jzack
20:27:50 08/21/12
um...ok, maybe it's not a scratch...
inf
21:44:33 08/21/12
Duh - didn't scroll over enough on the image, now I
jzack
20:33:49 08/22/12
zellamay
23:49:14 08/21/12
the wire wheel actually smoothed it out a lot, but It...
inf
01:14:08 08/22/12
I'd still find a way to smooth out that surface.
zellamay
02:12:51 08/22/12
I'd really try to get a flat file up into that space. Even
Gordo 93TT Daytona
08:17:08 08/22/12
Yes. Hopefully, I'd have thought of that if I were on the
zellamay
11:20:00 08/22/12
I just fear the file will remove parts of the flat surface
inf
12:06:12 08/22/12
It's a matter of technique. Gently with a fine-tooth file.
zellamay
12:38:27 08/22/12
2nd. Use a light touch to take off the peaks. When you put
Gordo 93TT Daytona
14:06:01 08/22/12
The gasket doesn't go all the way to the bearing though -
inf
01:17:05 08/22/12
I'm slow, I just got what you are saying here. Filing down
zellamay
08:40:01 08/23/12
