TwinTurbo.NET: Nissan 300ZX forum - It doesn't even go through, from outside to inside.
Subject It doesn't even go through, from outside to inside.
Posted by zellamay on August 21, 2012 at 11:49 PM
  This message has been viewed 188 times.
In Reply To Scratched gasket surface on transmission front cover posted by inf on August 21, 2012 at 07:11 PM
Message I'd sand it smooth, make sure there are no protrusions, and put it together. What your're trying to do is get it flat, so a wire wheel is a bad idea. I'd use a file and keep it flat on the surface. It doesn't look like you damaged the surface inboard of the dent, but make sure with a straight-edge.
