TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Does this RTV job look safe?
Subject Re: Re: Does this RTV job look safe?
Posted by preprodigy on August 21, 2012 at 4:28 AM
  This message has been viewed 246 times.
In Reply To Re: Does this RTV job look safe? posted by Tech@EPR on August 21, 2012 at 12:59 AM
Message yeah im my honest opinion that bead of silicone should have been on the outer edge of the pan opposed to the inner edge, this will help to prevent any silicone from squishing out into the oil pan itself and clogging up your oil pickup tube. also a smaller bead would be good, once you have pan on and tightened down you can always add a bead around outside edge and smooth with finger to ensure no leaks are present. a much better alternative then oil starvation due to an excess of silicone inside the pan edge. id redo it once more. 3rd times a charm ;)
