TwinTurbo.NET: Nissan 300ZX forum - It would be the timing belt being off, not the cas position.
Subject It would be the timing belt being off, not the cas position.
Posted by Woody75 (Denver) on August 20, 2012 at 1:27 PM
  This message has been viewed 273 times.
In Reply To can bad timing cause low compression? posted by SaphireZ on August 20, 2012 at 11:41 AM
Message So if the belt is not lined up right is can cause lower compression. The cas postion wont effect compression but with the belt off you can get the cas into spec timing wise still. If you have to crank the cas all the way to a side to get 15 degrees it would be a good indication that the belt is off on the teeth count.
JackB nimble JackB quick JackB can suck my dick =P - james-lee 11/02/01
Arrogance is the #1 weapon against Supra Owners - MikeH 08/06/02
Dallas with a Z: I like the bulge dude 05/02/03
Bezbefootball: Does dick have anything for me? 10/21/03
