TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Compression test.. i think im finished.
Subject Re: Re: Compression test.. i think im finished.
Posted by puchy on August 20, 2012 at 12:10 PM
  This message has been viewed 239 times.
In Reply To Re: Compression test.. i think im finished. posted by AddictedToBoost on August 19, 2012 at 05:05 PM
Message I will agree with the post above, specially with the throttle being close, because it will put your numbers around 100psi with the throttle close. This is what I would do- Do the test again WOT and make sure the adapter Orings are tight, if the numbers stay the same try another gauge. If #s are still the same, then is time to start looking for the root cause of the low compression starting with cam timing.
