TwinTurbo.NET: Nissan 300ZX forum - The IACV can be removed from the rear of the plenum. There
Subject The IACV can be removed from the rear of the plenum. There
Posted by Gordo 93TT Daytona on August 18, 2012 at 4:37 PM
  This message has been viewed 262 times.
In Reply To Re: It is probably stuck in the closed position. The screw is posted by DomZ32TT on August 18, 2012 at 03:00 PM
Message are four (4) 10mm bolts after removing the air hoses. You need to get the screw backed out in order to set the idle properly.
_________________________________________________
