TwinTurbo.NET: Nissan 300ZX forum - It is probably stuck in the closed position. The screw is
Subject It is probably stuck in the closed position. The screw is
Posted by Gordo 93TT Daytona on August 18, 2012 at 2:38 PM
  This message has been viewed 287 times.
In Reply To Idle Adjustment Screw Will Not Turn posted by DomZ32TT on August 18, 2012 at 01:50 PM
Message a simple needle valve, pointed at the end, and has probably been turned too tightly. Back it off (counter clockwise) and you should be OK.
_________________________________________________
