TwinTurbo.NET: Nissan 300ZX forum - Re: Compression test.. i think im finished.
Subject Re: Compression test.. i think im finished.
Posted by AddictedToBoost on August 19, 2012 at 5:05 PM
  This message has been viewed 240 times.
In Reply To Compression test.. i think im finished. posted by SaphireZ on August 19, 2012 at 04:26 PM
Message Sounds suspicious that all of your numbers are unifomly low.
Did you do a wet test yet? Was the engine warm when you tested it (could make a big difference)? All of the spark plugs pulled? Fuel relay pulled? Throttle open? Is the valve timing verified?
