TwinTurbo.NET: Nissan 300ZX forum - I'm gonna say it's probably the speed sensor located on the
Subject I'm gonna say it's probably the speed sensor located on the
Posted by Haasz32 on August 14, 2012 at 2:53 PM
  This message has been viewed 185 times.
In Reply To My (speedometer)+(odometer) stopped working? posted by zzmontyzz on August 14, 2012 at 02:15 PM
Message transmission, or the wiring from it.
You can pull the speed sensor out and test the output to see if it's working or not. It's kind of a pain since you need to drop the catalytic converters to be able to pull the sensor out of the tranny. But once it's out, it's easy to test by spinning the plastic gear and reading the voltage generated between the connector leads.
The other thing it might be is the speedometer connections in the guage cluster itself, as the soldering is known to break down with age. Ask me how I know. But, I was thinking the P/S won't work in that scenario, and it will work if it's the speed sensor that's the culprit.
