TwinTurbo.NET: Nissan 300ZX forum - remove the spark plug on number 6
Subject remove the spark plug on number 6
Posted by aliaZ on August 14, 2012 at 1:00 PM
  This message has been viewed 215 times.
In Reply To Ok, I got a working gauge... posted by inf on August 14, 2012 at 12:46 PM
Message turn the ignition on so that the fuel pump cycles
look into the cylinder on number 6. if it is wet with fuel you either have a bad o-ring or the injector is stuck open.
You may have to rotate the crank to get the valves to open on number 6 before you see fuel
