TwinTurbo.NET: Nissan 300ZX forum - Well apparently that 180 psi isn't an error..
Subject Well apparently that 180 psi isn't an error..
Posted by inf on August 14, 2012 at 12:56 PM
  This message has been viewed 228 times.
In Reply To Ok, I got a working gauge... posted by inf on August 14, 2012 at 12:46 PM
Message cylinder 2 had 180 psi dry...dang...and I used two different gauge tops.
I'm not sure if I mentioned it, but cylinder six still has a drop in rpm during the power balance test, just not as drastic as any of the others.
Although the bleeding fuel pressure and misfire support the idea of a leaking o-ring the spark plug is dry and I lubed the crap out of the o-ring, pushed it in by hand and then evenly screwed on the new hex screws. I even went as far as to swap PTUs.
I can take a video of the misfire though if anyone would like...
