TwinTurbo.NET: Nissan 300ZX forum - TT flywheel diameter should be 321mm, 12 5/8"
Subject TT flywheel diameter should be 321mm, 12 5/8"
Posted by RL7 on August 13, 2012 at 10:53 AM
  This message has been viewed 251 times.
In Reply To Re: Re: SR20DET flywgeel on VG30DETT posted by wantboost on August 13, 2012 at 05:14 AM
Message And that is what mine measures (tip of one tooth to tip of opposite tooth). I have what I think is an auto flex plate and it only measures about 12". Not sure what that's all about, I've read it's supposed to be 317mm.
I didn't know you were swapping bellhousings. To use a slightly smaller flywheel the bellhousing can be ground down where the starter mounts if necessary.
