TwinTurbo.NET: Nissan 300ZX forum - Re: SR20DET flywgeel on VG30DETT
Subject Re: SR20DET flywgeel on VG30DETT
Posted by RL7 on August 12, 2012 at 8:46 PM
  This message has been viewed 222 times.
In Reply To SR20DET flywgeel on VG30DETT posted by wantboost on August 11, 2012 at 04:54 AM
Message The na flywheel is smaller than the tt by 3-5 mm and it's likely the same diameter as the sr. People shim the starter to use the larger flywheel. Sometimes the crankshaft bolt patterns are offset slightly, but they should be the same on these two engines.
If the transmission you are using already works with the clutch you are using it should just be a matter of whether the flywheel bolts to the engine.
