TwinTurbo.NET: Nissan 300ZX forum - I just had this same problem
Subject I just had this same problem
Posted by Rocket man on August 12, 2012 at 3:25 PM
  This message has been viewed 265 times.
In Reply To IDLE issues--hunting idle posted by rudeboi805 on August 12, 2012 at 12:29 AM
Message I found out that the cause for my problem was an improperly adjusted base idle. The system works by a base idle that allows a certain amount of air to bypass the throttle bodies by adjusting a "base idle screw" on the drivers side of the plenum near the fire wall. Then the air idle controller etc. makes additional adjustments to fine tune the idle. On mine the base idle was off so far that the computer controlled idle system couldn't compensate enough.
If the base idle is adjusted too low it will give systems like yours. If it's too high you'll just have a very high idle all the time.
Here is a great link explaining the system better should you need to rebuild the various components.
Idle components explained
90 300zx TT 13.285@106.08 (old stock turbo set up)
94 Camaro Z28 13.751@101.83
03 WRX 13.973@94.88
02 Mazda MPV; four kids and a wife don't fit in the Z.
90 240sx (sold) 16.9@87
