TwinTurbo.NET: Nissan 300ZX forum - Input on remote start wiring
Subject Input on remote start wiring
Posted by Silens on August 12, 2012 at 10:56 AM
  This message has been viewed 217 times.
Message So following a guide I found on this site as a rough template I got my security system mostly hooked up. Everything works but the remote start, so I am troubleshooting it. I wanted some input on my wiring of the ignition harness from you guys who know way more about Z wiring than me. My ignition harness now looks like:
The system is a Viper 533
My harness calls for these connections to be made:
Starter output to starter
Starter input from ignition
3x +12v
Output to accessory
Output to primary ignition circuit
Output to second ignition circuit
I wired these up like so:
(ignition harness) -> (harness being splice in for remote start)
Black/White (ignition) -> Output to primary ignition
Red/White (+12v) -> all 3 +12v
Black/Green (Starter 2) -> Output to second ignition circuit
Blue (accessory) -> Output to accessory circuit
I cut the Black/Yellow ignition wire and did the following:
Black/Yellow car side (starter relay car side) -> Starter output to starter side
Black/Yellow key side (starter relay key side) -> Starter input from ignition
This is the first question, is this wired up acceptably? The car cranks fine, just the remote start is not working.
Thanks as always.
