TwinTurbo.NET: Nissan 300ZX forum - Re: Re: SR20DET flywgeel on VG30DETT
Subject Re: Re: SR20DET flywgeel on VG30DETT
Posted by wantboost on August 12, 2012 at 6:06 AM
  This message has been viewed 269 times.
In Reply To Re: SR20DET flywgeel on VG30DETT posted by Dane (Houston) on August 11, 2012 at 07:32 PM
Message you're listing the friction surface diameter... thats irrelevant for my application as i'm using a 7.25" triple plate... not a large single disc clutch. So I can use an na bellhousing without moving the starter? the reason I ask is i am not using a z32 transmission but a t-5 tremec dog box, I just need the z32 bellhousing for its obvious use. We modify the automatic bellhousings at the transmission end to simply bolt up a t5.
