TwinTurbo.NET: Nissan 300ZX forum - Re: IDLE issues--hunting idle
Subject Re: IDLE issues--hunting idle
Posted by Medallion Man on August 12, 2012 at 3:35 AM
  This message has been viewed 375 times.
In Reply To IDLE issues--hunting idle posted by rudeboi805 on August 12, 2012 at 12:29 AM
Message lol... that is the problem with these cars.... if you take it to just any garage they won't have a clue...
first make sure the car has had proper maintenance.
Check all the connectors you can find (some are a real pain to get off, be careful and take your time, it can be done).
make sure it has the right spark plugs, check the coil packs, injectors, MAS, TPS & PTU (the service manual shows how).
[ http://z32.wikispaces.com/Factory+Service+Manual ]
Check the timing (with as timing light, 15 TDC), you can also check and adjust the idle..... IAA
[ http://z32.wikispaces.com/Idle+Control ]
[ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.335 ]
the unit can also be removed and cleaned but before you do that, it may not be the cause.
These cars take a lot of care (remember they are old).
good luck.
