TwinTurbo.NET: Nissan 300ZX forum - Re: SR20DET flywgeel on VG30DETT
Subject Re: SR20DET flywgeel on VG30DETT
Posted by Dane (Houston) on August 11, 2012 at 7:32 PM
  This message has been viewed 335 times.
In Reply To SR20DET flywgeel on VG30DETT posted by wantboost on August 11, 2012 at 04:54 AM
Message sounds like 240mm vs 250mm
TT has a 250mm flywheel
NA has a 240mm flywheel
both have 8 bolt holes for the crank shaft
if your SR is 240mm then you have to use a NA bell housing trans for the start to reach the flywheel ring gear.
are we on the same track?
Houston Z
www.houston-nissans.com
