TwinTurbo.NET: Nissan 300ZX forum - Problem Adjusting the Timing, Seeking for help....
Subject Problem Adjusting the Timing, Seeking for help....
Posted by tt_703 on August 11, 2012 at 4:09 PM
  This message has been viewed 238 times.
Message My timing is really off, check with the timing light, the timing mark is out of range maybe at 45 degree. However the engine runs fine with very little misfire, at least that what i think. I have turned the CAS all the way to the right and still can't bring the mark to anywhere near 15 degree
A bit of info about my car
-1990 tt
-freshly rebuild engine
- everything is new, including later style EFI harness and newer style CAS
- nismo 740 and 300 degree rail
- ashspec tuned ECU
Things I have done
Remove the CAS and visually check (everything look fine)
-ECU code 55
-get signal at engine 1 coil and Ptu (same result)
- the belt was installed using The Tech page, all lines on the belt line up all the spockets , however I did not count the tooth. Auto tensioner at 4mm gap. HELP IS REALLY APPRECIATE...
