TwinTurbo.NET: Nissan 300ZX forum - Re: Is mil on ck codes tps iac timing vacuum leaks fpr. Get help
Subject Re: Is mil on ck codes tps iac timing vacuum leaks fpr. Get help
Posted by Krazyd27(Houston) on August 11, 2012 at 2:19 PM
  This message has been viewed 251 times.
In Reply To Is mil on ck codes tps iac timing vacuum leaks fpr. Get help (n/m) posted by craigz96tt on August 11, 2012 at 01:30 PM
Message What I think he meant was there is a million possibilities. Check ecu for codes, check the tps voltage, idle air control, check your timing and adjust the cas if necessary. Check all your hoses for vacuum leaks or hissing, check your fuel pressure with a gauge. And my favorite check your compression. Ohm out your injectors wiggle your harness/connections to see if the problem persists or disappears all together, clean all your connections including ptu. The list goes on and on my friend. Let us know if you solved the
issue and what was the cause
