TwinTurbo.NET: Nissan 300ZX forum - Re: Clutch/Brake Honking
Subject Re: Clutch/Brake Honking
Posted by Medallion Man on August 11, 2012 at 8:53 AM
  This message has been viewed 183 times.
In Reply To Clutch/Brake Honking posted by Khronik on August 09, 2012 at 02:11 AM
Message as far as the clutch fluid goes, are there any leaks in the foot-well, did you pull the carpet back to see?
if it's the slave you should be able to tell, pull the rubber boot back/off and see if it's leaking.
if you can get it up on hoist or ramps and press the pedal while someone checks for leaks.
