TwinTurbo.NET: Nissan 300ZX forum - Re: It's a normally open switch so the only way to test it
Subject Re: It's a normally open switch so the only way to test it
Posted by RL7 on August 11, 2012 at 12:02 AM
  This message has been viewed 128 times.
In Reply To It's a normally open switch so the only way to test it posted by DVDBURN (MD) on August 08, 2012 at 06:34 PM
Message You can bench test it with a paper clip and a multimeter. Normal is no continuity across pins. Push the paper clip into the hole on the sensor and there should be continuity.
