TwinTurbo.NET: Nissan 300ZX forum - Yes it should still start... You can do a number of tests to
Subject Yes it should still start... You can do a number of tests to
Posted by JonnyZ(SoCal) on August 10, 2012 at 7:02 PM
  This message has been viewed 210 times.
In Reply To det sensor and reppressurize fuel system???? posted by mcquitster on August 10, 2012 at 04:55 PM
Message find the problem, info on this topic is discussed quite a bit if you search. But heres a lil info to get you started!
Assuming that your battery is good/charged I would start with these few things
-check your fuel pressure (if good check injector connectors for corrosion/clean if needed)
-injector ohm test
-check your spark plugs/ensure they are sparking
if all these check out you can move on to more advanced tests: timing, coils, ptu, compression etc.
