TwinTurbo.NET: Nissan 300ZX forum - Gurus correct me if I am wrong, but...
Subject Gurus correct me if I am wrong, but...
Posted by Ted (92TT) on August 10, 2012 at 5:36 PM
  This message has been viewed 172 times.
In Reply To Re: Re: Cas postion posted by AddictedToBoost on August 10, 2012 at 04:22 PM
Message The ECU cannot alter your physical timing, since it is based on a physical relationship between hardware and the CAS trigger mechanism. The ECU assumes that the base physical timing is accurately set and adjusts electronically from there. So if you want to "fool" the ECU, you can adjust your base timing and everything else is adjusted correspondingly. Or conversely, leave base timing alone and adjust the ECU timing to electronically achieve the same result (more or less).
