TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Cas postion
Subject Re: Re: Cas postion
Posted by AddictedToBoost on August 10, 2012 at 4:22 PM
  This message has been viewed 198 times.
In Reply To Re: Cas postion posted by sky z on August 10, 2012 at 01:07 PM
Message Yes I know. New to 300zx cars, but not cars in general. I checked with two different timing lights. Also, in my opinion you need to use programs like datascan to confirm commanded timing before adjusting phase of the dizzy or cas. What if the ECU is commanding 17° at idle .... does you no good to set it to 15°???? Setting timing without a program like datascan is not the best way to do it.
My question is whether the required adjustment of the cas is indicative of valve timing issues or wether it is an accepted amount of cas rotation.
