TwinTurbo.NET: Nissan 300ZX forum - Does the ECU actually have to be TT? From what I understood
Subject Does the ECU actually have to be TT? From what I understood
Posted by evan_aggie on August 07, 2012 at 11:51 PM
  This message has been viewed 297 times.
In Reply To Native TT ecu, TT fuel pump controller and TT wiring are posted by Bernie (NoVA) on August 07, 2012 at 09:07 PM
Message the ECU output still has a pin (35? purple wire) that the harness sends out to the fuse relay in the engine bay. On a NA, the wire will end there. I took that wire and ran it directly from the harness to the TT FPC. If you did not have a TT harness, you may need to take the wire from the ECU all the way to the FPC.
