TwinTurbo.NET: Nissan 300ZX forum - As the picture shows - a common problem that comes
Subject As the picture shows - a common problem that comes
Posted by jzack on August 07, 2012 at 7:11 PM
  This message has been viewed 146 times.
In Reply To JWT setup.. code 34 posted by SaphireZ on August 07, 2012 at 11:18 AM
Message up with that connector. I just cut off the connectors all together and fitted the wire ends to insulated crimp on type connectors (reversing the male/female side for each wire so they always plug together the right way - no mixed up wires).
Have had it this way for years with no issues and the connectors they tuck away nicely behind/below the balance tube. If your decide to fix this way -- be sure to slip some heat shrink tubing over all the wire ends and then once all the connectors are crimped - shrink the tubing over the ends of the crimp connectors, keeps moisture out of everything. Pretty easy fix to make too...
