TwinTurbo.NET: Nissan 300ZX forum - I had the same problem
Subject I had the same problem
Posted by Stokens (StoMoZTT) on August 07, 2012 at 2:20 PM
  This message has been viewed 198 times.
In Reply To JWT setup.. code 34 posted by SaphireZ on August 07, 2012 at 11:18 AM
Message This is what mine looked like and the write-up I used to fix it:
http://www.twinturbo.net/nissan/300zx/forums/technical/view/1126847/Skip-the-resistor-trick-and-relocate-the-sensor.html
Of course, like the writeup says, it's not ideal - but it works until you can find a permanent solution. (ie pull the motor and put it back to stock location.)
If I would have known addiction was this expensive I would have seen a shrink a long time ago. --BadZCar (FL)
