TwinTurbo.NET: Nissan 300ZX forum - don't rely on the stock gauge, it's not linear
Subject don't rely on the stock gauge, it's not linear
Posted by Ahmed (Chicago) on August 07, 2012 at 11:52 AM
  This message has been viewed 159 times.
In Reply To Engine overheating. need help posted by tian2bing on August 07, 2012 at 05:50 AM
Message first you need to measure the actual temps with Nissan Datascan or get a handheld temp gauge...it should be around 175-190...if you are getting above 200, then you have an issue
it could be (most likely):
1) thermostat
2) water pump
3) fan clutch (this is what caused my overheating)
in a properly cooling car, the aux fan shouldn't have to come on at all, so that's prob not the problem. start with what I mentioned. if you search, there is a way to test the fan clutch with the 'spin test'
