TwinTurbo.NET: Nissan 300ZX forum - Re: backfire issue worst fear... bad gasket?
Subject Re: backfire issue worst fear... bad gasket?
Posted by Medallion Man on August 06, 2012 at 3:21 AM
  This message has been viewed 329 times.
In Reply To backfire issue worst fear... bad gasket? posted by SaphireZ on August 05, 2012 at 10:31 PM
Message that is some car.... I can see you've put the work in...
All that money and upgrades and you don't have diagnostic software!
I can't be positive but there are a few things to check.
And #1 is top of the list for likely cause...
[ http://pexcom.com.au/z32cms/e107_plugins/content/content.php?content.393 ]
1 - ecu temp sender unit (if not working will cause issues when car is warm) the one with the two wires.
2 - clean all connectors you can find (mainly CAS, PTU, TPS & MAF).
3 - what plugs did you use? should be PFR6B-11C
4 - check all earth/ground connections
5 - check and adjust TPS.
[ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.221 ]
6 - after doing the TPS check and adjust the timing... with a timing light (by turning the CAS)
[ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.225 ]
and this is interesting...
[ http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.226 ]
7- If it isn't the temp sender unit then it could be a fuelling issue so check the pressure regulators, pump & fuel ecu.
good luck..
