TwinTurbo.NET: Nissan 300ZX forum - Check oil pressure with a mechnical gage at the filter>>
Subject Check oil pressure with a mechnical gage at the filter>>
Posted by ZUL8TR on August 04, 2012 at 6:56 AM
  This message has been viewed 141 times.
In Reply To What would you test before writing a motor off... posted by XTZ2 on August 03, 2012 at 04:06 PM
Message area for a direct read rather than the factory gage and sender. Check the compression and compare results to factory. Check cooling system for exhaust gases due to leaking head gasket and oil in the coolant or coolant in the oil. Check engine vacuum at idle and at 2000rpm shoul be about a very steady 19 to 20 Hg and increase about 1 to 2 Hg at 2000 rpm. The important thing here is the needle should be STEADY no vibs at a steady rpm.
Do you use oil or coolant?
If you are not a mechanic you are going to have to rely on one or some friend who is mechanically inclined.
ZUL8TR in Orlando,FL
