TwinTurbo.NET: Nissan 300ZX forum - Claification: I mean using a timing light before the TB >>
Subject Claification: I mean using a timing light before the TB >>
Posted by ZUL8TR on August 04, 2012 at 6:47 AM
  This message has been viewed 223 times.
In Reply To Re: Before you changed the TB did you check the timing>> posted by syphon0202 on August 03, 2012 at 02:16 PM
Message replace and leave the CAS setting alone. Then after the TB replace check the timing with a light and if all work done correctly with the belt lineup the timing mark will be in the same exact spot as before the TB was replaced. If a tooth was missed on line up the timing mark will not be in the same spot.
ZUL8TR in Orlando,FL
