TwinTurbo.NET: Nissan 300ZX forum - Sounds like it should be good as long as tensioner was set
Subject Sounds like it should be good as long as tensioner was set
Posted by JonnyZ(SoCal) on August 03, 2012 at 3:26 PM
  This message has been viewed 181 times.
In Reply To Re: He is talking about using a timing light to make sure your posted by syphon0202 on August 03, 2012 at 03:10 PM
Message properly... but defiantly check your timing, also you should probably check your tps before you do the timing just to be on the safe side!
Good luck with your issues
