TwinTurbo.NET: Nissan 300ZX forum - He is talking about using a timing light to make sure your
JonnyZ(SoCal)
on August 03, 2012 at 2:20 PM
Re: Before you changed the TB did you check the timing>>
posted by syphon0202
on August 03, 2012 at 02:16 PM
At 15 degrees. Also when you did the belt, did you count the cogs? Things can look good but it's easy to be off a tooth and still look like it's set properly.
300zx idling poorly after some work
syphon0202
10:05:44 08/03/12
Re: 300zx idling poorly after some work
Stokens (StoMoZTT)
11:04:52 08/03/12
Re: Re: 300zx idling poorly after some work
syphon0202
12:28:31 08/03/12
ZUL8TR
13:25:23 08/03/12
syphon0202
14:16:14 08/03/12
He is talking about using a timing light to make sure your -
JonnyZ(SoCal)
14:20:20 08/03/12
Re: He is talking about using a timing light to make sure your
syphon0202
15:10:02 08/03/12
Sounds like it should be good as long as tensioner was set
JonnyZ(SoCal)
15:26:02 08/03/12
Re: Sounds like it should be good as long as tensioner was set
syphon0202
15:30:22 08/03/12
That should be fine. (n/m)
Summeronthechain (MN)
09:12:58 08/06/12
Claification: I mean using a timing light before the TB >>
ZUL8TR
06:47:42 08/04/12
