TwinTurbo.NET: Nissan 300ZX forum - Re: Does the same issue happen to 3 when coil packs are
Subject Re: Does the same issue happen to 3 when coil packs are
Posted by Ztrix on August 03, 2012 at 2:29 AM
  This message has been viewed 190 times.
In Reply To Does the same issue happen to 3 when coil packs are posted by jzack on August 02, 2012 at 09:00 PM
Message no. plus i just replaced the coil. i checked the voltage on the signal wire in the clip and it was reading 0 when running. if i let it sit for an hour or so after it stops firing it will run perfect. im feeling like its the ptu. i havent relocated it and im sure that wire shorting out didn't do it any justice...just doesn't make sence when the wires aren't messed up and its just cyclinder 3.
