TwinTurbo.NET: Nissan 300ZX forum - It sounds like your flooding to a stall.
Subject It sounds like your flooding to a stall.
Posted by DAYTONAZ on August 02, 2012 at 7:26 PM
  This message has been viewed 245 times.
In Reply To So frustrated trying not to give up. posted by SaphireZ on August 01, 2012 at 08:07 PM
Message You'll want to check the fuel pressure regulator and the fuel pressure dampner located on either side of the upper plenum in plain view. If either of those two, or both have a ruptured diaphram they will suck fuel into the intake at idle when vacuum is greatest.
Give either a quick smell test by removing the vacuum hose and smelling for fuel or looking for evidence of fuel. To properly test them you should use a vacuum tester which simply is a hand pump that will pay for itself the first time you use it.
