TwinTurbo.NET: Nissan 300ZX forum - Re: hoses checked out ok... im at a loss... PTU?
Subject Re: hoses checked out ok... im at a loss... PTU?
Posted by Silens on August 02, 2012 at 1:05 AM
  This message has been viewed 157 times.
In Reply To hoses checked out ok... im at a loss... PTU? posted by SaphireZ on August 01, 2012 at 10:48 PM
Message Have you checked your timing? I had an issue where my timing was retarded by something like 25 degrees. Was running super rich due to a bunch of unburnt fuel. The symptoms were similar, ran mediocre (only noticeable as a lack of power, especially on the bottom end) when the engine was over 1k rpm, but ran awful below that.
I would assume if you were getting an all clear it's probably not your PTU. Also you would be getting misfires, which should be fairly obvious.
If you are getting an all clear from the ECU that eliminates some of the other typical "running too rich" areas, so start with timing.
