TwinTurbo.NET: Nissan 300ZX forum - NEO BULBS ARE NOW DIFFERENT...they are glued to the plastic
Subject NEO BULBS ARE NOW DIFFERENT...they are glued to the plastic
Posted by itZjoker on August 01, 2012 at 11:04 PM
  This message has been viewed 1864 times.
In Reply To How to replace the OEM control pod lamps with LED lamps. posted by DVDBURN (MD) on June 09, 2009 at 12:33 AM
Message lamp holders.
The 4mm neos are fine since you don't have to remove the bulb. But the neos are now glued to the plastic and when you try and remove the bulb from the lamp holder, the leads will break.
I had to solder the tiny ass leads back on and it was a pain in the ass. The resister and diodes also look different from your picture and some may not fit perfectly into the oem lamp housing.
If I could do it over, I would have done it the old fashion way and solder the LED directly onto the pods for the 3mm and 5mm bulbs. The 4mm NEO are perfect since you do not need to remove them from the housing.
