TwinTurbo.NET: Nissan 300ZX forum - Going from 35's to 50's is a diameter increase from>>
Subject Going from 35's to 50's is a diameter increase from>>
Posted by ZUL8TR on August 01, 2012 at 10:30 AM
  This message has been viewed 361 times.
In Reply To Very intrigued by this. posted by megaDan on August 01, 2012 at 08:32 AM
Message 25.303 to 28.433 or about 12.3% increase. You are correct that the rpm will be reduced about 300. And greater diameter tires last longer, less revs per mile. If you have the Hp go for it.
When I was 1/4 mile drag racing back when, tire diameter reduction (specifically with smaller rims) was an effective way to increase acceleration if certain gears were not available and it was less costly to boot. We also increased tread width when using smaller rims for traction control.
ZUL8TR in Orlando,FL
