TwinTurbo.NET: Nissan 300ZX forum - Or maybe its the other way around ? Post your fuel map (n/m)
ztunerz
on July 30, 2012 at 10:56 PM
Re: What happens to your vaccum when you turn thing on and off ?
posted by 94ttz32
on July 30, 2012 at 10:27 PM
Airfuel goes lean when headlights and ac are cut on!
94ttz32
11:19:35 07/29/12
Alty voltage regulator is one thing that comes to mind...
jzack
11:27:03 07/29/12
Re: Alty voltage regulator is one thing that comes to mind...
94ttz32
11:34:04 07/29/12
Re: Re: Alty voltage regulator is one thing that comes to mind...
ouikikazz
11:49:06 07/29/12
Re: Re: Re: Alty voltage regulator is one thing that comes to mind...
94ttz32
11:54:10 07/29/12
Alternator. Drop by any auto parts store - they can test it
ConVerTT
17:21:20 07/29/12
When mine is fully warmed up i have the same readings as you (n/m)
Dane (Houston)
14:26:53 07/29/12
Re: When mine is fully warmed up i have the same readings as you
94ttz32
14:37:15 07/29/12
yes low 13s at idle, but with ac and headlights on
Dane (Houston)
18:46:17 07/29/12
Re: yes low 13s at idle, but with ac and headlights on
94ttz32
20:06:55 07/29/12
is it possible your pulley is larger than stock on your
Dane (Houston)
21:41:59 07/29/12
But given the alty is a heavy duty unit compared to OEM --
jzack
20:10:03 07/29/12
are you using the narrowband emulator from your wideband?
aliaZ
23:37:36 07/29/12
Re: are you using the narrowband emulator from your wideband?
94ttz32
00:42:03 07/30/12
ok...not sure what to suggest then...
aliaZ
06:07:42 07/30/12
Re: ok...not sure what to suggest then...
94ttz32
08:03:16 07/30/12
What happens to your vaccum when you turn thing on and off ? (n/m)
ztunerz
21:23:21 07/30/12
94ttz32
22:27:18 07/30/12
Or maybe its the other way around ? Post your fuel map (n/m) -
ztunerz
22:56:04 07/30/12
