TwinTurbo.NET: Nissan 300ZX forum - I had a fuel smell after CC removal that was caused by the
Subject I had a fuel smell after CC removal that was caused by the
Posted by Gordo 93TT Daytona on July 30, 2012 at 9:03 PM
  This message has been viewed 823 times.
In Reply To Carbon canister removed and smell even worse!! posted by Hydrus on July 29, 2012 at 12:53 PM
Message outlet fitting on the vent line. Shown below where the vent line terminates into a fitting shown by the bottom green arrow in Robo's picture (From Robo's Website).
This fitting is shaped like an upside down 'U'. As such it has a low spot in which fuel vapor would condense and pool. When the car was shut off, residual tank pressure would force a small amount of the collected liquid fuel out through the check valve on the end, and it would evaporate to cause the smell. To fix the problem, I simply removed the fitting which was the source of collect gasoline. I allowed the vent line to hang straight down which prevented any fuel from collecting; and evaporating later. Since I made this simple fix, the fuel smell is gone.
_________________________________________________
