TwinTurbo.NET: Nissan 300ZX forum - Help with miss/hesitation/misfire
Subject Help with miss/hesitation/misfire
Posted by Summeronthechain (MN) on July 29, 2012 at 3:14 PM
  This message has been viewed 280 times.
Message Hey TT.net,
I need some help.
My car has a slight miss. It is barely noticeable at idle and remains all through the rev range when the engine is cold and warm. The results of this are lack of power, lower throttle response, and a small vibration felt through the shifter.
I recently did some service to my car including timing belt, new EFI harness, and plenum pull. Car ran perfect prior.
Some troubleshooting I already did:
-Code 55 on ecu(no malfunctions)
-Double checked spark plugs, all look good.
-All coil packs ohmed out good
-Check EFI connections, all good with the exception of bypassed systems(PRVR, AIV, EGR, stock boost control solenoids).
-Double checked for boost leaks - Holds pressure well.
-Removed coil pack connectors with car running and car drops in revs and chugs when I remove each one.
-Removed and reinstalled timing belt, double checking my timing marks
-Switched out CAS/TPS
-Cleaned MAF/connections
