TwinTurbo.NET: Nissan 300ZX forum - Just realize, putting a digital meter across the two
Subject Just realize, putting a digital meter across the two
Posted by jzack on July 29, 2012 at 8:48 AM
  This message has been viewed 206 times.
In Reply To Re: So one side has +12v and the other constant ground? posted by hiimmarkie1990 on July 28, 2012 at 07:33 PM
Message connectors on the harness plug and measuring volts isn't determining that you've found a constant ground. That meter isn't placing any real load on the circuit. One way to figure this out is to put a resistor in series with an LED across the connector and see if it lights up. That would indicate a constant ground condition...
