TwinTurbo.NET: Nissan 300ZX forum - So one side has +12v and the other constant ground?
Subject So one side has +12v and the other constant ground?
Posted by jzack on July 27, 2012 at 10:57 PM
  This message has been viewed 203 times.
In Reply To Re: No - that's how it fires. ECU grounds the injector as posted by hiimmarkie1990 on July 27, 2012 at 09:02 PM
Message That means the injector is always on. If that's the case it may be fried - they aren't supposed to be powered for a long span of time - burns out the coil.
How did you determine it has constant ground? Explain the steps followed to make that measurement with your meter? Key in car on or off? etc...
I'm thinking something isn't being measured right?
Also use your meter (resistance, ohms setting) and measure this injector. Tell us what reading you get -- should be low in the 10 to 14 ohm range if the injector is good.
