TwinTurbo.NET: Nissan 300ZX forum - Re: No - that's how it fires. ECU grounds the injector as
hiimmarkie1990
on July 27, 2012 at 9:02 PM
posted by jzack
on July 27, 2012 at 08:35 PM
My injector has a constant ground so how would I fix that?
injector problem
hiimmarkie1990
19:41:04 07/27/12
Did you ohm the injector? Pre 95 wiring harnesses always
PiotrC70
19:55:50 07/27/12
Re: Did you ohm the injector? Pre 95 wiring harnesses always
hiimmarkie1990
20:09:03 07/27/12
jzack
20:35:49 07/27/12
Re: No - that's how it fires. ECU grounds the injector as -
hiimmarkie1990
21:02:46 07/27/12
So one side has +12v and the other constant ground?
jzack
22:57:32 07/27/12
Re: So one side has +12v and the other constant ground?
hiimmarkie1990
19:33:01 07/28/12
Just realize, putting a digital meter across the two
jzack
08:48:41 07/29/12
