TwinTurbo.NET: Nissan 300ZX forum - Did you ohm the injector? Pre 95 wiring harnesses always
Subject Did you ohm the injector? Pre 95 wiring harnesses always
Posted by PiotrC70 on July 27, 2012 at 7:55 PM
  This message has been viewed 228 times.
In Reply To injector problem posted by hiimmarkie1990 on July 27, 2012 at 07:41 PM
Message had power at the injector connector. This is has been discussed as a contributing factor to premature injector failure. There are topics on the forum about rewiring which kills power to the injectors when the car is off, but I digress. Ohm out your injector and you should be between 12-14 with ideal being 12.5 if i remember correctly. If it's outside of that, your injector is going bad or is toast.
1993 TT. R.I.P. 09.15.2010
