TwinTurbo.NET: Nissan 300ZX forum - I've had both (re: gussets)
Subject I've had both (re: gussets)
Posted by BlackholeZ on July 27, 2012 at 1:15 AM
  This message has been viewed 269 times.
In Reply To I saw that post, b I have an hoist anyway. How about the posted by evan_aggie on July 26, 2012 at 09:56 AM
Message On my motor I was able to loosen the gusset and get the pan out. I didn't want to make yet another run to the store for another gasket, so I wanted to make it work.
I just tried the same technique on a customer motor and could not get the gusset loose, so I had to pull the oil tree. It ended up being necessary though, as one of the check valves in the block had come apart.
-Dan
BlackholeZ VTC Solenoid Caps
Installation Procedure
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" - ChristopherTheOne
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
"You're the Skrillex of Z32s." BradX (UF)
